Clash Manager User Guide
Design Workflow : Clash Set Execution
8.
You can now run the clash check either from the Tools>Run Clash Set menu option or from the Clash Sets Form and subsequent Run Clash Set Form. Alternatively, the clash set can be run as a batch job overnight using mmscmd and Windows scheduled tasks. The results are presented on Clash Reports. (If you have any doubt that the clash set has run successfully, you should check the Log Files.) You can organise the report arrangements to suit your requirements and you can filter the content using the Clash Report Filter Form.
Refer to: Running a Clash and Viewing Clash Report.
