Clash Manager
Concepts
: Access Rights
Access Rights
Clash Manager Administrator privileges, unlike other Model Management Administrator rights, are based on Windows Login IDs and are set directly using Clash Manager itself. This difference exists to enable Clash Manager to be used without an installation of VPE Workbench.
The arrangements for access rights to Clash Manager cover two aspects, namely User Access Levels and Security Levels.
The User Access Levels aspect enables the Administrator to specify the users who are to be the Members and Supervisors of each discipline.
The Security Levels aspect enables the Administrator to specify whether members or supervisors of particular disciplines may change Clash Status, acquire Clash Ownership, perform Clash Checks of the Current Element and/or add Comments to clash records. Each of these is respectively covered by a separate Security Level namely, Clash, Owner, Clash Check CE and Comments.
There are no options to set a Security level for preparing and running clash checks, setting up Clash Manager options and carrying out the 'Advanced Tasks'. These functions can be carried out only a Supervisor of the ADMIN discipline.
For each Security Level there are five pre-defined states namely, High, Medium High, Medium, Medium Low and Low. Each of these states has corresponding settings (minimum requirements). The default State for each Security Level is Medium and this is used as the guideline when access rights are mentioned in the Clash Manager Procedures.
As required, the Administrator may override the pre-determined settings by specifying custom settings for one or all of the
Security
Levels.
