Multi-Discipline Supports User Guide
Welding Application : Position Welds on a Framework or Special Pick
1.
Select either the Single Position or Start & End radio button.
2.
Select Pick on the Framework Weld Selection window (Figure 9:1.: Framework Weld Selection window). In either case, the Set Weld Position window is displayed. Welds can be made on either a single Pline or on Pline Intersections.
On the Set Weld Position window:
1.
Select the Single Pline radio button.
2.
Click Identify Pline.
1.
Select the Pline Intersections radio button. The available intersecting sections are populated in the list and the Set Weld Position window appears as shown in Figure 9:4.: Set Weld Position window (Pline Intersections).
2.
Click on the upper Identify Pline and select the first (owning) Pline that requires the weld.
3.
Click Identify SCTN and select the section containing the intersecting Pline.
4.
Click on the lower Identify Pline and select the intersecting Pline.
