Multi-Discipline Supports
Administrator Guide
MDS Lighting Support Defaults
Loading the Form
: Support : Bracket Limit
If the support height (in mm) is less/greater than this value, then bracket(s) will be removed from or added to the support. The Bracket Limit may also be specified locally within the support template.
