Multi-Discipline Supports
Administrator Guide
MDS Trunnion Defaults Form
Standard Tab
: Trunnion Sizes
Trunnion Sizes
The Trunnion Size is the length of the trunnion from the bottom of the trunnion baseplate, (not the bearing plate) to the centre of the pipe to which it is welded/clamped.
The minimum and maximum trunnion size for the selected trunnion type and pipe bore can be set here, as well as the default trunnion size (length).
