Multi-Discipline Supports Administrator Guide
MDS Structure Defaults Form
The MDS Structure Defaults form defines which of the available support standards can be used in a project, and clients replacement support names and descriptions can be specified.
MDS Framework types prefixed FT can be organised into groups, which makes selection of a framework easier for the MDS designer.
Alternative codes can be defined to replace the MDS application default codes to suit the clients standard.
Changes are only applied to the database when the Apply button is clicked. The Dismiss button removes the form. If changes have been made, but not applied, a window is displayed asking if the changes are to be applied before exiting.
