To generate an Upgrade macro file in an existing 11.6 project currently using the MDS application.
The Upgrade macro file contains the names of all the current MDS ATTA and PLAT element types in the current MDB along with the attribute values for the SPREF and the UDA :MDSMATREF for these element types.
Important:
Only run the generated Upgrade macro file in an already Upgraded 12 version of the project. This is an existing 11.6 project version which has already been Upgraded to a 12 project version via the standard AVEVA PLANT 12 Upgrade procedure for an existing 11.6 project. Plus the existing 11.6 project running MDS has been Upgraded via the standard AVEVA MDS12 Defaults Upgrade utility found in the PARAGON module.
