Multi-Discipline Supports
Administrator Guide
MDS Support Standards
: Lugs
Lugs
The following standards are available in the
MDS
application. Refer to
Modifying User Defined Ancillary Geometry
for information on User Defined Lug Standards.
MDS
Standard Name
Replacement Name
Default Description
LT01A
XLT01A
Shear Lug (Lug Only)
LT01B
XLT01B
Shear Lug (With riser clamp)
LT01C
XLT01C
LT02
XLT02
Vertical Support w/lug for NPS 1/2-4
LT03A
XLT03
Type A CS and Alloy Support Lug for Vertical Pipes NPS 2-3
LT03B
XLT03
Type B CS and Alloy Support Lug for Vertical Pipes NPS 4-24
LT03C
XLT03
Type C SS Support Lug for Vertical Pipes NPS 2-3
LT03D
XLT03
Type D SS Support Lug for Vertical Pipes NPS 4-24
LT04
XLT04
Support Lug for vertical Hot insulated pipes NPS 2-36
LT05A
XLT05
Rod Hanger Welded Elbow Lug for 1/2" Pin/Bolt Diameter NPS 2-18
LT05B
XLT05
Rod Hanger Welded Elbow Lug for 5/8" Pin/Bolt Diameter NPS 2-18
LT05C
XLT05
Rod Hanger Welded Elbow Lug for 3/4" Pin/Bolt Diameter NPS 3-18
LT05D
XLT05
Rod Hanger Welded Elbow Lug for 7/8" Pin/Bolt Diameter NPS 3-18
LT05E
XLT05
Rod Hanger Welded Elbow Lug for 1" Pin/Bolt Diameter NPS 3-18
LT05F
XLT05
Rod Hanger Welded Elbow Lug for 1.1/8" Pin/Bolt Diameter NPS 4-18
LT05G
XLT05
Rod Hanger Welded Elbow Lug for 1.3/8" Pin/Bolt Diameter NPS 4-18
LT05H
XLT05
Rod Hanger Welded Elbow Lug for 1.5/8" Pin/Bolt Diameter NPS 6-18
LT06
XLT06
Single Support Bracket Reinforced Vertical Pipe (Cu-Ni Pipes) NPS 2-24
LT07
XLT07
Vertical Support on Platforms for Diam 2" to 8"
LT08A
XLT08
Rod Hanger Welded Pipe Lug for 1/2" Pin/Bolt Diameter NPS 2-18
LT08B
XLT08
Rod Hanger Welded Pipe Lug for 5/8" Pin/Bolt Diameter NPS 2-18
LT08C
XLT08
Rod Hanger Welded Pipe Lug for 3/4" Pin/Bolt Diameter NPS 3-18
LT08D
XLT08
Rod Hanger Welded Pipe Lug for 7/8" Pin/Bolt Diameter NPS 3-18
LT08E
XLT08
Rod Hanger Welded Pipe Lug for 1" Pin/Bolt Diameter NPS 3-18
LT08F
XLT08
Rod Hanger Welded Pipe Lug for 1.1/8" Pin/Bolt Diameter NPS 4-18
LT08G
XLT08
Rod Hanger Welded Pipe Lug for 1.3/8" Pin/Bolt Diameter NPS 4-18
LT08H
XLT08
Rod Hanger Welded Pipe Lug for 1.5/8" Pin/Bolt Diameter NPS 6-18
LT09
XLT09
GRE / CPVC Pipes Vertical Support on Platforms for Diam 2" to 8"
LT10
XLT10
GRE / CPVC Pipes saddle shear lug bearing for Diam 1.1/2" to 24" (Type A) Vertical only
LT11
XLT11
GRE / CPVC Pipes saddle shear lug bearing for Diam 1.1/2" to 24" (Type B) Horizontal only
LT12
XLT12
GRE Pipes saddle shear lug bearing for Diam 26" to 40" (Type C) Horizontal only
LT13A
XLT13A
Welded Lugs (1 Lug) for Carbon Steel and Stainless Steel 2" to 24"
LT13B
XLT13B
Welded Lugs (4 Lugs) for Carbon Steel and Stainless Steel 2" to 24"
LT14A
XLT14A
Welded Lugs (2 LugS) for Carbon Steel and Stainless Steel 2.5" to 24"
LT14B
XLT14B
Welded Lugs (1 Lug) for Carbon Steel and Stainless Steel 2.5" to 24"
LT15
XLT15
Welded Lugs (4 Lugs) for guide for Carbon Steel and Stainless Steel 2" to 24"
LT16A
XLT16A
Welded Lugs (4 Lugs) for Carbon Steel and Stainless Steel 2.5" to 24"
LT16B
XLT16B
Welded Lugs (6 Lugs) for Carbon Steel and Stainless Steel 2.5" to 24"
LT17
XLT17
Welded Lugs (2 Lugs) for Guide for Carbon Steel and Stainless Steel 2" to 24"
