Multi-Discipline Supports
Administrator Guide
MDS Support Standards
: Guides
Guides
The following standards are available in the
MDS
application.
The standards marked with a * are not available in the
MDS
application. These standards are obsolete and have been replaced by other new standards. Refer to
Modifying User Defined Ancillary Geometry
for information on User Defined Guide Standards.
MDS
Standard Name
Replacement Name
Default Description
GT01
XGT01
Pipe guide for insulated pipes.
GT02
XGT02
Pipe guide for uninsulated pipes.
GT03
XGT03
Pipe guide for uninsulated pipes. Thin wall.
GT04*
XGT04
Pedestal guide or stop.
GT05
XGT05
Pipe guide (Framework).
GT06
XGT06
Guide for support shoe (Welded to support Beam) NPS 1-36.
GT07
XGT07
Guide Lug for support shoe (Welded to support Beam) NPS 3/4-36.
GT08
XGT08
Guide Lug for support shoe (Bolted to support Beam) for temporary transport.
GT09
XGT09
Box Clamp Guide for medium loads NPS 6-18 (Framework).
GT10
XGT10
Box Clamp Guide for high loads NPS 20-42 (Framework).
GT11
XGT11
Guide for Base Support NPS 2-36
GT12A
XGT12
Pipe A Base Support Guide Hold Down Light NPS 2-36
GT12B
XGT12
PIpe R Base Support Guide Hold Down Light NPS 2-36
GT13
XGT13
Cradle and Guide For Cold Service (30mm 150mm Insulation), NPS 1/2 2.
GT14
XGT14
Heavy Duty Guide Cold (Cryogenic) Service, NPS 3 42.
GT15
XGT15
Pipe Guide, Uninsulated pipe, NPS 1 42.
GT16
XGT16
Box Clamp Guide for medium loads NPS 6-18.
GT17
XGT17
Box Clamp Guide for high loads NPS 20-42.
GT18
XGT18
Guide for pipe shoes for diam 2" to 24"
GT19
XGT19
Lateral Guide for diam 26" to 56"
GT20
XGT20
Duckfoot guide hold down.
GT21
XGT21
Shoe guide hold down.
GT22
XGT22
Overstrap Guide (C.S./Alloy Pipes), NPS 1/2 24
GT23A
XGT23A
Overstrap Guide c/w Isolation Wrap XAT36 (Cu-Ni Pipes), NPS 2 24
GT23B
XGT23B
Overstrap Guide c/w Isolation Wrap XAT37 (Cu-Ni Pipes), NPS 2 24
GT24
XGT24
Overstrap Guide with Damper Springs, NPS 1/2 24
GT25
XGT25
HALFEN Guide HCS RADDV NPS 1" 6"
GT26
XGT26
Guide Lugs for Support shoes Light Angle/Channel Sections NPS 3/4-36.
GT27A
XGT27
Pipe A Base Support Guide Hold Down Heavy NPS 2-36
GT27B
XGT27
PIpe R Base Support Guide Hold Down Heavy NPS 2-36
GT28
XGT28
Guide Lugs for Support shoes Heavy Angle/Channel Sections NPS 3/4-36.
GT29
XGT29
CPVC Pipes Flat Clamp 2" to 6"
GT38
XGT38
GRE Pipes Flat Clamp 2" to 6"
GT39
XGT39
Guides for pipes without insulation 2" to 6"
GT40
XGT40
Band Guides for pipes 2" to 24"
GT44
XGT44
Guide and Hold down welded 2" TO 12"
GT45
XGT45
Guide for bare pipe 2" TO 24"
GT46
XGT46
Pipe Guide, welded, for pipe shoe with sliding package 2" TO 24"
GT47
XGT47
Guide, Clamped to steel, Type A
GT48
XGT48
Clamped Guide on steel structure, Type B
GT49
XGT49
Guide welded extended height
GT50
XGT50
XS Strap Guided 6" TO 28"
GT52
XGT52
Pipe Shoe and Guide - NPS 15-1400”
GT54
XGT54
Guide Clamps for Pipes with Insulation 2” to 24”
GT55
XGT55
