Multi-Discipline Supports
Administrator Guide
MDS Support Standards
: Multi-discipline Framework Supports
The following standards are available in the
MDS
application.
The standards marked with a * are not available in the
MDS
application. These standards are obsolete and have been replaced by other new standards.
MDS
Standard Name
Replacement Name
Default Description
FT01*
XFT01
Trapeze hanger with welded beam attachments.
FT02*
XFT02
Trapeze hanger.
FT03
XFT03
'L' Bracket up.
FT04
XFT04
'L' Bracket down.
FT05
XFT05
'L' Bracket Cantilever.
FT06
XFT06
FT07
XFT07
Post.
FT08
XFT08
Goal post.
FT09
XFT09
Support frame.
FT10
XFT10
Half goal post (Vertical down).
FT11
XFT11
Half goal post (Vertical up).
FT12
XFT12
Goal post (Heavy weight).
FT13
XFT13
Braced bracket.
FT14
XFT14
Cantilever bracket.
FT15
XFT15
Beam supports.
FT16
XFT16
Cantilevered Hangertrue
FT17
XFT17
'T' Post heavy weight.
FT18
XFT18
'T' Post light weight. (Vertical up).
FT19
XFT19
'T' Post light Weight. (Vertical down).
FT20*
XFT20
Deck Plate Stiffening.
FT21
XFT21
Support from piping.
FT22
XFT22
Bedplate.
FT23
XFT23
Pedestal support.
FT24
XFT24
Steel sleeper.
FT25
XFT25
Packing piece.
FT26
XFT26
Relief Valve.
FT27
XFT27
Rodding point.
FT28
XFT28
Beam penetration.
FT29
XFT29
Base Support for 1/2 2 N.S. pipe.
FT30
XFT30
Pipe Support for Relief Valve Discharge Pipe NPS 2-12
FT31
XFT31
Field Support L frame Uninsulated Pipe (1 Pipe, NB 4 Max)
FT32
XFT32
Field Support L frame Uninsulated Pipe (2 Pipes, NB 3 Max)
FT33
XFT33
Field Support Cantilever from Steel for Uninsulated Horizontal Pipe.
FT34A
XFT34A
Field Support Type A Angle Iron for Uninsulated Pipe, Single line NPS 1/2 to 12.
FT34B
XFT34B
Field Support Type B Angle Iron for Uninsulated Pipe, Single line NPS 1/2 to 12.
FT34C
XFT34C
Field Support Type C Angle Iron for Uninsulated Pipe, Single line NPS 1/2 to 2.
FT35
XFT35
Field Support for Vertical Uninsulated Lines NPS 24 Max.
FT36
XFT36
Field Support frame.
FT37
XFT37
Field Support Goal Post frame.
FT38
XFT38
Field Support Field Installed Structural Steel NPS 1/2 to 24.
FT39
XFT39
FT40
XFT40
Field Support Field Installed Structural Steel NPS 1/2 to 12.
FT41
XFT41
Inverted Pedestal support.
FT42
XFT42
Support frame for vertical pipes
FT43
XFT43
Depth Support frame
FT44
XFT44
GRE/CPVC Pipes 150vertical valve support pipe 2" to 20" dia\PIPE-REST
FT45
XFT45
GRE/CPVC Pipes 150valve support and anchor pipe 2" to 20" dia\PIPE-REST
FT46
XFT46
GRE/CPVC Pipes Base support at flange (150#) pipes 2" to 16" dia\PIPE-REST
FT47
XFT47
Supports for Flanged Valves NPS 2.1/2" to 24"
FT48A
XFT48A
Pedestal support for 2" to 24" pipes.
FT48B
XFT48B
FT48C
XFT48C
FT48D
XFT48D
FT49
XFT49
Support frame for vertical pipes with lugs LT13 or LT15 2.1/2" to 48" pipestrue
FT50
XFT50
Support Bar and Clamp for 2.1/2" to 24" pipestrue
FT51
XFT51
Goal Post with vertical or Angled Legs
FT52
XFT52
Guide for Vertical Pipes
FT53
XFT53
Guide for Horizontal Pipes
FT57
XFT57
Guide for Vertical Pipes with Insulation 2” to 24”
FT58
XFT58
Support Bar and Clamp NPS 2 1/2” to 24”
FT59
XFT59
FT60
XFT60
FT61
XFT61
Fixed Point Support NPS 3/4” to 32”
