Multi-Discipline Supports
Administrator Guide
MDS Support Standards
: U bolts
U bolts
The following standards are available in the
MDS
application. Refer to
Modifying User Defined Ancillary Geometry
for information on User Defined U Bolt Standards.
MDS
Standard Name
Replacement Name
Default Description
BT01A
XBT01
U Bolt gripped (type A)
BT01B
XBT01
U Bolt non-gripped (type B)
BT02
XBT02
U Bolt tico coated
BT03
XBT03
U Bolt PTFE coated insulation
BT04A
XBT04
U Bolt Guide (GB) Black, NPS 1/2 36.
BT04B
XBT04
U Bolt Guide (GG) Galvanised, NPS 1/2 36.
BT04C
XBT04
U Bolt Guide (GP) Plastic Coated, NPS 1/2 36.
BT05
XBT05
U Bolt gripped with sleeve, NPS 2 24.
BT06
XBT06
U Bolt Guide for Cupro Nickel Lines, NPS 1/2 8.
BT07
XBT07
U Bolt Guide for Carbon Steel Lines, NPS 1/2 8.
BT09
XBT09
Lined U-Bolt guided 2" TO 8"
BT10
XBT10
U Bolt Guide, NPS 1/2 - 36”
BT11
XBT11
Loose Type U Bolt Guide, NPS 1/2 - 36”
BT12
XBT12
U Bolt for steel pipe, NPS 1/2 - 3”
BT13
XBT13
U Bolt for steel pipe, NPS 4 - 32”
BT14
XBT14
Expansion U Bolt for steel pipe, NPS 1 - 32”
BT15
XBT15
Lined U Bolt NPS 1 1/4 - 2”
BT16
XBT16
Lined U Bolt NPS 2 1/2 - 36”
BT17
XBT17
U Bolt for use with slip pad NPS 1/2 - 32”
BT18
XBT18
U Bolt with Teflon Pad NPS 2 1/2 - 32”
BT19
XBT19
Expansion U Bolt with Slip Pad NPS 1 - 32”
