Multi-Discipline Supports
Administrator Guide
MDS Support Standards
: Anchors
Anchors
The following standards are available in the
MDS
application.
The standards marked with a * are not available in the
MDS
application. These standards are obsolete and have been replaced by other new standards.
Refer to
Modifying User Defined Ancillary Geometry
for information on User Defined Anchor Standards.
MDS
Standard Name
Replacement Name
Default Description
AN01A*
XAN01A
Pedestal Anchor Type A.
AN01B*
XAN01B
Pedestal Anchor Type B.
AN02
XAN02
Pipe Shoe Anchor.
AN03
XAN03
Pipe Shoe Anchor.
AN04
XAN04
Bolted Anchor shoe for Hot insulated pipe or temp transport NPS 2-36.\AT12,AT13,PIPE-REST\PIPE-REST\
AN05
XAN05
Temporary restraint NPS 2-20.
AN06
XAN06
Bolt on Shoe w/Directional Anchor Cold (Cryogenic) Service (50/100mm Insu) NPS 3 48
AN07A
XAN07
Anchor U Bolt (AB) Black, NPS 2 20.
AN07B
XAN07
Anchor U Bolt (AG) Galvanised, NPS 2 20.
AN07C
XAN07
Anchor U Bolt (AP) Plastic Coated, NPS 2 20.
AN08
XAN08
Pipe Clamp Anchor For RTR Pipe NPS 2-24.
AN09
XAN09
Overstrap Anchor (C.S./Alloy Pipes) NPS 1/220
AN10
XAN10
Directional Anchor NPS 1-36.
AN11
XAN11
Bolt On Anchor For Galvanised Pipe NPS 6-12.
AN12A
XAN12A
Flat Clamp for CS pipes NPS 1.1/2-16.
AN12B
XAN12B
Flat Clamp with Neoprene Sleeve for SS pipes NPS 1.1/2-16.
AN13
XAN13
HALFEN Anchor HCS RADV NPS 1" 6"
AN17
SC47
Anchor U Bolt for Cupro Nickel Lines, NPS 1/2 8.
AN18
SC15
Anchor U Bolt for Carbon Steel Lines, NPS 1/2 8.
AN19
XAN19
Anchor - NPS 15-1400
