Multi-Discipline Supports Administrator Guide
Hangers Design Templates : Configuration of the Hangers Design Templates
When the MDS application creates a hanger of a given configuration, it copies the required hanger template. In order for the application to know which template it should copy, a specific naming convention is used. Each hanger configuration has a name (e.g. FH01, VH01). As explained in the overview each zone represents a single hanger configuration. The names of the zones have the following formats:
/MDS/FH**
/MDS/VH**
/MDS/FH**/pipe_size_in_mm
For example, a REST having the name /MDS/FH01/100 represents a template for a hanger with a FH01 configuration, used for a 100mm pipe. In some cases the hanger designer may need different hanger sizes for the same pipe size. A good example of this is when a hanger is attached to a welded elbow lug. The lug may have a range of holes sizes. So, although the hanger configuration type is the same and the pipe size is the same, a lug with a larger hole will require a larger pin and a hanger with larger rods. This is handled by adding a one-letter suffix to the name of the REST and is compatible with AVEVA’s standard naming convention used in the hangers catalogue for rod sizes. For example, suffix A is used for an M6 rod size, B for an M8 rod size etc. A typical template name for such a hanger may be: /MDS/FH01/100/A. This template is for hangers with the FH01 configuration, connected to a 100mm pipe and having M6 rod size.
Refer to Naming Conventions for further information.
The range of sizes available for a given hangers configuration, as well as other specific configuration data, is set when the hangers feature of the MDS application is used for the first time in a session. The application then scans the MDS hangers template site: /MDS/HANGERS, reads the zones attributes, and saves it in memory for later use. The range of available hanger sizes for each configuration is determined from the restraints elements below the zone.
