Multi-Discipline Supports Administrator Guide
Introduction : Administrator’s Role
The administrator is responsible for the initial setup of the defaults associated with the MDS application. This document describes the defaults that can be modified by the administrator in order to configure MDS to specific project requirements.
Most of the MDS defaults are stored in a PARAGON database, and are viewed or modified using a series of forms. The remainder of the defaults are stored in four text files, in which the appropriate fields are modified in a text editor by the administrator.
MDS Application Defaults
MDS Ancillary Defaults
MDS Hanger Template Defaults
MDS Structure Defaults
MDS Trunnion Defaults
DRA-MDS-ABA-DEFAULTS - holds the default values for MDS ADP (automatic drawing production).
MDS-REPORT-DEFS - holds the pre-defined MDS reports available for the project.
MDS-REPORT-HEADINGS - holds the definition of a list of Alternative Report Headings that are applicable to the pre-defined reports.
