ISODRAFT
Command Reference Section
: UNITS
UNITS
Function:
Specifies units of measurement used for ISODRAFT’s output.
Description:
The units used for length and bore dimensions on isometric drawings can be specified independently from the units used for input data.
By default, lengths along pipelines (for component dimensioning, tube lengths, etc.) are shown in metric units, and pipe bores are shown in imperial units.
That input units are specified by the commands BORES and DISTANCES.
Examples:
UNITS METRIC
Outputs metric lengths and metric bores.
UNITS IMPERIAL
Outputs imperial lengths and imperial bores. Measurements between 1’ and 2’ will be output in inches; for example, 15”.
UNITS IMPERIAL FT
Outputs imperial lengths and imperial bores. Measurements between 1’ and 2’ will be output in feet and inches; for example, 1’3”.
UNITS METIMP
Outputs metric lengths and imperial bores.
Related Commands:
BORES DISTANCES
Command Syntax:
>--- UNIts ---+--- METRic -----.
|--- IMPerial ---+--- FT ---.
‘--- METImp* ---------------+--->
Querying:
Q OUTPut UNIts
Q OPTions
Q UNITS gives the current units for
input
measurements (refer to BORE and DISTANCE commands),
not
output measurements.
