ISODRAFT
Command Reference Section
: TTFONT
TTFONT
Function:
Allows the user to choose a font type for all the text on the isometric (including material description).
Description:
Different font types can be defined in the Admin module by the user. The user can then choose one of the defined font types. One of the available types is used as the default type when the option is on. This feature should only be used when the FILE command specifies that isometrics files are to be produced in DXF, PDF, Image or EMF (Enhanced Windows Metafile) format (refer to
FILE
Examples:
TTFONT OFF
True type fonts are not used.
TTFONT ON
Selected true type font is used.
TTFONT 5
Times New Roman font type as defined in Admin.
TTFONT 6
Arial font type as defined in Admin.
TTFONT NONE
True type font are not defined in Admin
Command Syntax:
>- TTFONT -+---+- ON --.
| '- OFF -+-->
+- integer --+
- NONE -----+------>
Querying:
Q TTFONT
