ISODRAFT
Command Reference Section
: SPECBREAK
SPECBREAK
Function:
Specifies the level at which a change of pipeline specification is noted, and which changes are recorded on the isometric.
Description:
Pipeline specification changes are indicated by notes against the corresponding points on the isometric plot. By default, specification changes are noted at component level, but they can be noted at Branch level instead.
SPECBREAK BRANCH causes only changes in the Branch specification to be recognised.
SPECBREAK COMPONENT causes the Branch specification to be ignored and changes to be recognised only in the component attributes LSTUBE or SPREF, or in the Branch attribute HSTUBE.
The format in which a specification change is shown is that both the original and new specifications are shown at each point of change. The format is similar to that used for dimensioning.
SPECBREAK can be further modified to output specification changes for material, insulation, tracing, paint, and (up to) five user-defined specifications. By default, only specification changes for Pipe will be output. By switching SPECCHANGES to ON, the user can output the other changes.
The following Atext defaults are associated with the specification breaks on the drawing area:
Specification
Specification ATEXT
Spec Break ATEXT
Pipeline name
288 ‘PIPE’
288 ‘PIPE’
Material spec
253 ‘PIPING SPEC’
289 ‘MATL’
Insulation spec
270 ‘THERMAL INSULATION SPEC’
290 ‘INSUL’
Tracing spec
271 ‘TRACING SPEC’
291 ‘TRACE’
Painting spec
272 ‘PAINTING SPEC’
292 ‘PAINT’
Examples:
SPECB COMP
Recognises changes in component specifications only.
SPECB BRAN
Recognises changes in branch specifications only.
SPECB BRAN SPECC ON
Recognises changes in branch specifications only, and outputs specification changes for insulation, tracing and paint.
Command Syntax:
>- SPECBreak -+- COMPonent* -.
‘- BRANch -----+- SPECChanges -+- ON ---.
| ‘- OFF* -+
Querying:
Q SPECBreak
Q OPTions
