The FILE command specifies the name of the PLOT file for ISODRAFT output. ISODRAFT adds a three-digit number, jumping over any numbers which already exist. If DXF, PDF, image or EMF output is requested, the suffixes .dxf, .pdf, (.tif, .bmp, .jpg, .png, .dif), .emf will be added respectively after the number.
The AVEVA E3D™ limitation on plotting size is 3275mm2 and this cannot be exceeded in either single or multiple file mode.
Specifies that the PLOT file will be in DXF EUC format. The suffix .dxf is added to the filename automatically.
>- FILE -+- AND -.
| | +-------+- DXF -. | | | | '-------+- SHIFTJIS -. | | | | +- EUC ------| | | | | ‘------------| .---<---. | | / | ‘----------------------------+-*- PDF ---| | | +- PRINT -| | | +- IMAGE -| | | +- EMF ---| | | ‘---------+- filename -+- SINGle -------------. | | +-- MULTIple -+- value -| | | | | ‘---------| | | | | ‘-----------------------+-> |
where value is the maximum length of the plotter’s paper roll in millimetres.
