ISODRAFT
Command Reference Section
: COUNITS
COUNITS
Function:
Allows the user to specify in which units the coordinates are to be expressed.
Description:
This command allows the user to specify one of the following eight units in which the coordinates are to be expressed:
Examples:
MM
CM
METRE
FINCH
USFINCH
DECINCH
INCH
USINCH
millimetres. Example: 6263.48
centimetres. Example: 626.348cm
metres. Example: 6.26348m
feet and inches. Example: 20'6.19/32"
feet and inches (US style). Example: 20'-6 19/32"
decimal inches. Example: 246.59"
fractional inches. Example: 246.19/32"
fractional inches (US style). Example: 246 19/32"
Related Commands
COFORMAT, CODECP, COIMPP
Command Syntax
>--- COUNITs ---+-- MM -------.
|-- CM -------|
|-- METRE ----|
|-- FINCH-----|
|-- USFINCH---|
|-- DECINCH---|
|-- INCH------|
|-- USINCH -
The corresponding GUI appears on the Annotations Options window:
