ISODRAFT
Command Reference Section
: BOLTFILE
BOLTFILE
Function:
This specifies the name of the bolt report file produced via the BOLTREPORT command.
Description:
The bolt report file is an ASCII file. The user can specify a page length for the file (with a default of 55 lines), and whether the report should append to an existing file (default) or overwrite an existing file.
Examples:
BOLTF /BOLTREP1
Gives the resulting bolt report file the name BOLTREP1. If this file already exists, the information produced from the BOLTREPORT command will be added to the end of the existing file.
BOLTF /BOLTREP1 OVER
Specifies that the bolt report file should overwrite ANY existing file of the same name.
BOLTF /BOLTREP1 WI 70 LI
Specifies that the bolt report file name is BOLTREP1 and that it has a page length of 70 lines.
Related Commands
BOLTING BOLTREPORT MATERIALLIST
Command Syntax
>-----BOLTFile filename ---+---OVERwrite--------.
--WIth value LInes -+--->
