ISODRAFT
Command Reference Section
Command Summary
: Setting Up ISODRAFT
Setting Up ISODRAFT
COMMAND
Brief description
ADD
Adds named elements to the list of elements to be processed by the CHECK or DETAIL command.
CHANGE HIGHLIGHTING
Represents changed items on a drawing in a different colour pen.
CHECK
Extracts isometric data from the database but does not pass it to the plotting function. This is used to check the data or create a transfer file.
DELETE
Deletes an SKEY definition from a symbol library.
DETAIL
Generates and plots isometric drawings for the elements in the list.
FILE
Specifies the name of the PLOT file to which the isometric drawing output is sent.
INSTALLSETUP
Restores the settings to those saved in the macro or binary file using the RECREATE command.
MESSAGEFILENAME
Specifies the name of the file to which messages about the progress of the detailing are sent.
OPTIONS
Allows the user to reset all options to their default settings.
POSTPROCESS
Lets the user specify up to five system commands which are to be executed during ISODRAFT’s intermediate transfer file processing.
PROCESS
Instructs ISODRAFT to process a transfer file.
Query
Allows the user find the current settings of the options.
RECREATE
Creates a macro or binary file which can be read into ISODRAFT to restore the current settings.
REMOVE
Removes elements from the list to be detailed.
SETCOMPDATE
Sets the Comparison Date for an MDB or DB.
SYMBOLFILENAME
Specifies the name of a symbol library.
TRANSFERFILENAME
Allows the user to save a transfer file generated during ISODRAFT’S data extraction operations, for subsequent processing.
