HVAC
Administrator Guide
Auto Naming
Auto Naming
The HVAC Administrator may define 'auto naming' rules for HVAC elements and HVAC branches, however, it is expected that a user would define the HVAC and branch names.
With regard to component names (branch members) the user has a utility that allows the HVAC elements to be assigned an item number and named accordingly.
This utility is called from the
HVAC
tab, in the
Tools
group, click
Itemise
and applies the same rules as HVAC Spooling where works fitted items are given a subnumber, for example 3.1 is a branch connector which is fitted to the above item 3.
An item is defined as works fitted by the property WKSF true.
