The filter window lists all the values in the column, plus All and
Blanks. Next to each item in the list is a checkbox. To filter out a value from the column, uncheck its checkbox. To uncheck all values, uncheck the
All checkbox. Check the
All checkbox again to check all the checkboxes.
If the Blanks checkbox is checked, rows without a value in the column are displayed when the filter is applied.
When the required filter conditions have been selected, click OK to close the window and apply the filter. The value that the column is being filtered by is displayed in the filtering row field for the column.
More advanced filters can be applied by clicking Text Filters. A list of text filtering criteria is then displayed.
Click on the required criterion to display the Custom Filter window with the selected criterion populated.
The user can select All or
Any from the drop-down menu at the top of the window to filter on
All the selected conditions or
Any of the selected conditions. When the required filter conditions have been selected, click
