Equipment User Guide
Equipment : Modify : Sub-Equipment Origin
To modify a Sub-equipment origin using a cursor pick in the 3D view, on the Equipment tab, in the Modify group, click Sub-Equipment Origin, select ID Point from the drop-down list. The user is prompted to Identify the new origin point on the Sub-Equipment.
To modify a Sub-equipment origin using explicit position values, on the Equipment tab, in the Modify group, click Sub-Equipment Origin, select Explicit from the drop-down list to display the Modify SUBE Origin window.
From the drop down menu, click to identify the direction of the East/West axis. The user can then input an explicit position value in the Position field.
From the drop down menu, click to identify the direction of the North/South axis. The user can then input an explicit position value in the Position field.
From the drop down menu, click to identify the direction of the Up/Down axis. The user can then input an explicit position value in the Position field.
Click Apply to modify the origin point or Cancel to discard any inputs and close the Modify SUBE Origin window.
