Equipment User Guide
Equipment : Import Equipment Data
On the Equipment tab, in the Import group, click Data to display the Equipment Data Import browser window.
When the user has located the file, click Open to display the Equipment Data Import window.
Indicates that an Equipment already exists in the database. If the Load All Data function is actioned, then attributes of the Equipment are be modified. No action is taken on rows with this Icon if the Load New Data option is actioned.
Indicates that the system has identified a problem with this row of data. No action is taken on rows with this Icon when the Load All Data or Load New Data option is actioned. Selecting the row in the table displays a message in the Messages area of the window indicating why the row cannot be processed.
Click Load All Data to process all of the rows that create a new element or modify an existing element. Clicking Load New Data option only processes the rows that create new elements.
Select Undo to remove all of the changes made by the load operation and revert the database back to its state before the load, or to deal with the erroneous elements individually.
Import files can be loaded by using the File Open Icon, the Browse option or by typing a name directly into the Filename field on the Equipment Data Import window.
Click Reload Data to reload the current file in the Select File field. The user may find this necessary if the current element was incorrect or an owner element was missing when the file was first loaded.
It is possible to load element types other than Equipment using this function. The example above shows User Defined Element Types (UDETS, refer to User Defined Element Types for further information on equipment being created. If the imported file is carefully constructed it would be possible to import other element types provided that fields in the file contain all of the required data. For example, a nozzle list can be loaded provided that the owning equipment name is provided in an Owner field for each nozzle element, and the Type field identifies the element as a nozzle.
