Equipment
Equipment
Import-STL
: Reports
Reports
The standard report or log generated by Import-STL following a translation operation provides the following information:
a count of the primitives found and translated
a list of errors or warnings
An example of a report is given below:
AVEVA Everything3D - Import-STL REPORT
Date of run: Wed May 14 10:18:37 2008
Input StereoLithography file: C:\xxxxx\ slide_gate1.stl
Output PDMS Design macro file: C:\xxxxx\ slide_gate1.mac
Solid polyhedra are created
Primitives Processed
Number of faces read is 5380
Number of primitives recognised is 40
Number of Solid Shells is 15
Number of Boxes is 2
Number of Extrusions is 14
Number of Cylinders is 9
The smallest hole diameter exported is: 10
Input StereoLithography file: C:\AVEVA\ImPLANT-STLxxx.0\test\slide_gate1.stl
Output PDMS Design macro file: C:\AVEVA\ImPLANT-STLxxx.0\Macros\slide_gate1.mac
