The user can use the export option 'seedfile' '<filename>' command in MODEL to set the path of the seed file (note that the path of the file is needed, not the path of the folder, as in the case of the environment variable). For example
If the export option 'seedfile' is not set, then ExPLANT-I looks for a file named seed3d.dgn in a folder or search-path set in the environment variable SEED3D_DIR.
To use a configuration file, either the environment variable EXPLANT_CONFIGURATION must be set to the path of the configuration file; or the AVEVA E3D™ command export option 'configuration' '<filename>' must be called to set up a temporary path to the configuration file.
Export option 'seedfile'
'c:\seedfiles\seed1.dgn' |
