Equipment
Equipment
Export-DXF
: Error Messages
Error Messages
A more detailed error message may often be found in the log file.
The following message is output by MODEL if there is a problem with locating or loading the Export-DXF Export Driver.
Unable to open dynamic library
The following error messages may be output during translation from AVEVA E3Dâ„¢ to AutoCAD.
library does not accept this hardware
iogini has not been called
file does not exist
cannot close the file
end of file found
insufficient space provided
2D request on 3D file
3D request on 2D file
type does not exist
type is invalid for query routine
invalid level in type 9
invalid dimension
invalid exponent in double
group not applicable to type
attributes not applicable
Invalid export option:
Unknown error from export driver
