DRAW Reference Manual
Colours and Styles
Line Styles
: Using Glyphs
Using Glyphs
Glyphs are used in conjunction with LINEStyle elements. The LINEST's GLYNUM attribute defines the glyph to be used. This may be set as follows:
GLYNUM/ber OFF
(the default value)
GLYNUM SYS/temglyph 10
(in the range 1-25)
GLYNUM 3
(the GLYNO value of the required GLYPH)
GLYNUM /My-Glyph
The LINEST's DECSIZ attribute should be set to define the size to which the Glyphs REFSIZ value is to scaled.
