DRAW Reference Manual
Colours and Styles
: Colours
Colours
DRAW allows you to draw in up to 272 colours, numbered 1 to 272. By default all 272 colour numbers have colour definitions assigned to them:
Colour numbers 1 to 16 are assigned by default to the following colours:
Colour 1
Grey
Colour 9
Brown
Colour 2
Red
Colour 10
White
Colour 3
Orange
Colour 11
Pink
Colour 4
Yellow
Colour 12
Mauve
Colour 5
Green
Colour 13
Turquoise
Colour 6
Cyan
Colour 14
Indigo
Colour 7
Blue
Colour 15
Black
Colour 8
Violet
Colour 16
Magenta
Colour numbers 17 to 272 are mapped to the colours in the standard AutoCAD™ Colour Index (ACI).
The system maintains a dictionary of 61 colour names that may be used in place of colour numbers when specifying a colour or setting the value of a colour attribute. These names (which include the 16 given above) and their ACI (AutoCAD Colour Index) and RGB values are as follows:
COLOUR
ACI
RED
GREEN
BLUE
Black
0
0.000
0.000
0.000
White
7
1.000
1.000
1.000
Whitesmoke
7
1.000
1.000
1.000
Ivory
51
1.000
1.000
0.667
Grey
253
0.510
0.510
0.510
Lightgrey
254
0.745
0.745
0.745
Darkgrey
251
0.314
0.314
0.314
Darkslate
129
0.208
0.310
0.286
Red
12
0.741
0.000
0.000
Brightred
1
1.000
0.000
0.000
Coralred
22
0.741
0.180
0.000
Tomato
20
1.000
0.247
0.000
Plum
215
0.506
0.337
0.506
Deeppink
230
1.000
0.000
0.498
Pink
243
0.741
0.494
0.553
Salmon
21
1.000
0.749
0.667
Orange
40
1.000
0.749
0.000
Brightorange
40
1.000
0.749
0.000
Orangered
30
1.000
0.498
0.000
Maroon
226
0.408
0.000
0.306
Yellow
50
1.000
1.000
0.000
Gold
40
1.000
0.749
0.000
Lightyellow
51
1.000
1.000
0.667
Lightgold
41
1.000
0.918
0.667
Yellowgreen
62
0.553
0.741
0.000
Springgreen
110
0.000
1.000
0.498
Green
92
0.000
0.741
0.000
Forestgreen
84
0.122
0.506
0.000
Darkgreen
108
0.000
0.310
0.075
Cyan
4
0.000
1.000
1.000
Turquoise
132
0.000
0.741
0.741
Aquamarine
120
0.000
1.000
0.749
Blue
5
0.000
0.000
1.000
Royalblue
160
0.000
0.247
1.000
Navyblue
176
0.000
0.000
0.408
Powderblue
141
0.667
0.918
1.000
Midnight
168
0.000
0.075
0.310
Steelblue
142
0.000
0.553
0.741
Indigo
196
0.204
0.000
0.408
Mauve
204
0.376
0.000
0.506
Violet
221
1.000
0.667
0.918
Magenta
6
1.000
0.000
1.000
Beige
43
0.741
0.678
0.494
Wheat
31
1.000
0.831
0.667
Tan
32
0.741
0.369
0.000
Sandybrown
42
0.741
0.553
0.000
Brown
36
0.408
0.204
0.000
Khaki
55
0.506
0.506
0.337
Chocolate
38
0.310
0.153
0.000
Darkbrown
48
0.310
0.231
0.000
Blueviolet
190
0.498
0.000
1.000
Firebrick
30
1.000
0.498
0.000
Darkorchid
202
0.553
0.000
0.741
Dimgrey
252
0.412
0.412
0.412
Coral
22
0.741
0.180
0.000
Indianred
13
0.741
0.494
0.494
Lightblue
151
0.667
0.831
1.000
Limegreen
80
0.247
1.000
0.000
Mediumaquamarine
121
0.667
1.000
0.918
Sienna
34
0.506
0.251
0.000
Stateblue
173
0.495
0.494
0.741
The actual RGB definitions of these colours have generally changed so as to match entries in the ACI. This has led to duplication: thus White and Whitesmoke are both mapped to ACI 7, and Orange, Brightorange and Gold are mapped to ACI 40. The redundant colour names have been maintained for compatibility with previous versions of AVEVA Software.
It is possible to change the definitions of colours 1-16 using the COLOUR command. The syntax can take three forms, either specifying a predefined name from the system colour dictionary, or a percentage mixture, or an RGB definition. Typical examples would be:
COLour 3 STEELBLUE
COLour 12 MIX RED 80 GREen 50 BLUe 50
COLour 14 RGB 0, 141, 188
Where a percentage mixture is specified all three values must be in the range 0-100. Where an RGB definition is given all three values must be in the range 0-255.
Colour definitions can be queried thus:
Q COLour 12
Q COLour RGB 55
Colour attributes can be assigned values by number or name, thus:
LLCOLOUR 54
TXCOLOUR NAVYBLUE
When a colour attribute is queried the name (e.g. ‘orange’) will be returned if available, otherwise the colour number will be returned. If a number is specifically required (regardless of whether a name is available, a special colour-number pseudo-attribute should be used. The names of these are derived from the normal colour attributes, e.g. LLCONU/MBER, TXCONU/MBER, FCONUM/BER etc.
It is possible to set all colour attributes on an element to the same value by the ALLCOLOURS command. As some DRAW elements have many such attributes this is a convenient way of changing them to the same colour quickly. To set all the text colours and all the line colours separately the TEXTCOLOURS and LINECOLOURS commands should be used, thus, for example:
ALLCOLOURS
RED
TEXTCOLOURS
7
LINECOLOURS
GREEN
The list of colour attributes are listed. The special colour attribute values of DEFAULT, TEMPLATE, and UNCHANGED can also be specified but these are only valid in particular circumstances. Refer to the relevant sections of this User Guide for details of where these values are allowed.
