DRAW Reference Manual
Plotting and Drawing Output : LIEXEC Command (configurable DXF format) : Configuration Datasets
It is possible to control the format of DXF and DWG output using configuration datasets. The configuration dataset controls how the database information is to be mapped into DXF format. It does the following:
'R15' indicates the AutoCAD version number, and can be one of the following:
Example:
SWITCH GroupGLAB ON
Example:
DLICON name DUMP
DLICON name CHECK SWITCH switchname
DLICON name CHECK BLOCK element_identifier
Example:
