DRAW Reference Manual
Graphical Representation
Automatic Hatching
: Hatching Rules
Hatching Rules
Each Hatching Rule references a Hatch Style element that defines the hatch pattern to be applied. For each Hatch Rule you can specify:
Whether it applies to faces created by a section plane or to primitive surfaces.
The orientation of the faces to be considered for hatching. There are three options:
All Directions, in which case the face will be hatched regardless of its orientation.
Perpendicular Direction, in which case the face will only be hatched if it is perpendicular to the viewing direction.
Specified Direction, in which case the face will only be hatched if its normal matches a specified value. The normal of a face is the vector perpendicular to it and pointing out of the solid primitive. Thus the normal of the uppermost horizontal surface of a box is Up.
The HRUL attributes, with their defaults, are as follows:
Hatch Style Ref
HSTYF
reference to HSTYL, default null
Face Code
FCODE
Sectioned-Faces
Direction Code
DCODE
All-Directions
Face Normal
NORM
unset
Selection Criteria
CRIT
unset
Example:
HSTYF /HSTYL1
FCODE SECTionedfaces
FCODE PRIMitivefaces
DCODE ALL Directions
DCODE PERPendiculardirection
DCODE SPECifieddirection
NORM standard AVEVA direction syntax
CRIT standard AVEVA selection criteria syntax
As well as the usual NEW command, an HRUL can also be defined by:
USE hstyl FOR criteria
which will set the HSTYF and CRIT attributes.
