Refer to General Commands for further information about using expressions.
That it is possible to apply a selection criterion to a list of class types by enclosing them in brackets, for example:
USE /ST1 FOR (ALL BRAN ALL SUBS) WI (ZONE EQ /ZONE.PIPES) Without the brackets the selection criterion would only be applied to SUBS. Selection criteria should not be used unnecessarily. For example, if you wish to draw small-bore Branches in style /ST1 and the rest in style /ST2, it is only necessary to say: USE /ST1 FOR ALL BRAN WI (HBOR LE 80 OR TBOR LE 80) USE /ST2 FOR ALL BRAN As long as the criteria are defined in this order, all small-bore Branches will match the first criterion and the rest, having failed to match the first criterion, will match the second. |
