DRAW Reference Manual
Drawing the Design
: Summary of Commands
Summary of Commands
At Id List . . .
ADD
design_element_identifier
adds Design element to Id List.
REM
removes Design element from Id List
ADD ALL
FOR
REM ALL
WITH
( selection_criteria )
FOR
DESADD
adds Design element to 3D View.
DESREMOVE
removes Design element from 3D View
ADD ALL
FOR
LIMITS E
value
N
value
U
value
E
value
N
value
U
value
removes Design elements from ID List that are not wholly or partially contained within defined limits box.
LIMITS @ TO @
set limits as 3D coords with the cursor
LIMITS ID @ ID @
set limits as 3D coords via Design elements using the cursor
DELETE ENTRY
number
delete either an ADDE or REME from the Id List members - the number is the member list number
DELETE ADD
number
delete an Add item,
number
corresponding to number of the element out of the Adds only
DELETE REM
number
delete a Remove item,
number
corresponding to the number of the element out of the Removes only
