DRAW Reference Manual
Drawing the Design : Background Process Manager : Initiating and Using the BPM
3.
Issue an UPDATE DESIGN NOWAIT command, normally via associated applicationware.
6.
For each job the background DRAW session performs a special UPDATE DESIGN command that generates and stores each new VIEW in a separate intermediate view file or IVF. This is a picture file prefixed with the letter ‘X’ instead of the standard ‘M’.
9.
Issue an UPDATE REFRESH command to refresh the current VIEW (SHEET or DRAWING).
If a refreshed VIEW is unacceptable, you should NOT issue a SAVEWORK to save it permanently. Instead, the original SHEET should be re-selected to re-load the old contents.
Be careful to save any outstanding changes to other VIEWs in the same SHEET before refreshing another VIEW.
1.
Initiate the BPM by invoking the BPM.bat start-up file.
2.
The Background Process Manager form then appears, which displays details of each job together with its Status of ‘Not Started’ or ‘Finished’ and an exit code showing success or failure. Refer to Managing Jobs using the Background Process Manager Form for further information.
3.
Processing of ‘Not Started’ jobs is initiated from the Background Process Manager form. The form shows the job currently running and provides facilities to start job processing or stopping the current job, as required.
4.
When one or more jobs appear in the job list, click on the Start manager hyperlink to start the processing of jobs with Status ‘Not Started’. Note that the hyperlink changes to Stop manager at this point. The Background Process Manager form may be iconised at this point.
6.
The Background Process Manager form may then be restored, if necessary, to view the updated Status and Exit Codes. An exit code of ‘Success’ means that the updated VIEW (SHEET or DRAWING) can be refreshed into the foreground DRAW session.
7.
The Background Process Manager form can then be minimised and the Background Process notification icon cleared by right-clicking on it and then selecting the Clear Item option.
where: ddmmyyyy is the standard date and hhmmss is the standard time that the process was started. The log file should contain a record of all processing in the Background Process session, including errors.
