DRAW Reference Manual
Drawing the Design
Background Process Manager
: Prerequisites
Prerequisites
Certain environment variable settings must be defined before the BPM can be used:
AVEVA_DESIGN_EXE, since it contains the module to be executed in the background.
AVEVA_DESIGN_WK, since it contains the job XML file, the AVEVA E3D™ macro, the regenerated VIEW files and the DRAW log file. It also contains the BPM log file.
The project environment variables XXX000, XXXISO, XXXMAC and XXXPIC must be defined for each project XXX to which the BPM is applied.
A batch file
BPM.bat
is supplied to enable the above environment variables automatically and to start the BPM in much the same way as .bat enables to AVEVA E3D™ environment variables.
