DRAW Reference Manual
Drawing the Design : Querying Commands
Q VSCAN <SIGNIFICANT | design_id> <IN view_id> <FOR selection_criteria>
The IN view_id may be omitted if your current database position is at or below a View.
Q VSCAN design_id IN view_id
Q VSCAN IN view_id FOR selection_criteria
Q VSCAN FOR SCTN EXCL WITHIN E 800mm N 750mm U 638mm To E 900mm N 850mm U 738mm
In the examples, design_id must refer to a Design significant element, which is EQUI, SUBE, STRU, SUBS, FRMW, SBFR, TMPL, BRAN, or HANG.
It is possible but not recommended to enter the syntax:
Q VSCAN FOR SCTN WITHIN <volume> IN CE
In this case the "IN forms part of the generic selection criteria syntax (equivalent to "WRT CE") and is unlikely to be what the user is intended. The results may be very different from the probable intent of syntax, for example:
Q VSCAN IN CE FOR SCTN WITHIN <volume>
