DRAW Reference Manual
Drawing the Design : Changing the Picture by Changing VIEW Attributes : Ignoring the DUNION attribute
Refer to Controlling Edge Representation in DRAW for information on the use of the DUNION attribute on DESIGN elements such as FRMW, STRU, etc. The DUNION values are used during an UPDATE DESIGN process to determine whether common edges between FRMWs (say) should be drawn or omitted. However it is possible to ignore all DUNION values by setting the View's IGNDUN attribute (Ignore Dunion) to TRUE. (The default value is FALSE). After changing the IGNDUN attribute an UPDATE DESIGN will be required.
