DRAW Reference Manual
Drawing the Design
Changing the Picture by Changing VIEW Attributes
: View Size
View Size
SIZE
is the ‘paper size’ of the VIEW rectangle. Changing the size by a command such as
SIZE 400 400
leaves the scale of the VIEW contents unaffected, but moves the point at the centre of the picture to the centre of the new VIEW frame.
The SIZE attribute is also be changed by the VREGION command, which may be used to resize and reposition the VIEW. For example:
Example:
VREGION FROM @ TO @
Opposite corners of VIEW defined by cursor
VREG X100 Y100 TO X500 Y500
Opposite corners of VIEW defined explicitly
VREG AT @
Centre of VIEW defined by cursor
VREG corner AT @
Specified corner of VIEW defined by cursor:
TL
top left
TR
top right
BL
bottom left
BR
bottom right
C
centre
The default size is that of the owning Sheet. The VREGION command also affects the XYPS attribute (refer to
View Centre
for further information).
The SIZE command can also be used at SHEE level to change the Sheet size.
