DRAW Reference Manual
General and Database Commands
Database Commands
: Switching Between Databases
You can switch between the DESIGN, DRAW and Catalogue Databases using the command:
SWITCH
If the current element is in the DESIGN database, SWITCH will make the element last selected in the DRAW database current. Similarly, giving the SWITCH command when in the DRAW database will return to the element last selected in the Design database.
If the current element is a Catalogue Component, SWITCH will return to the last Design element accessed. You can go directly to the DRAW database or DESIGN Database using the commands:
CONTEXT DRAWING
CONTEXT DESIGN
