DRAW Reference Manual
2D Drafting
Where 2D Drafting is Used
: Symbol Templates
Symbol Templates
User-defined symbols (consisting only of 2D drafting elements) may be created as Symbol Templates (SYTMs). These can then be picked from a Library sheet element, with position, size and orientation attributes being altered to suit. The relevant part of the DRAW database hierarchy is shown overleaf.
Symbol Library (SYLB) and Label Library (LALB) elements can be regarded as ‘Sheets’ that can be displayed in an area view. Symbol Templates can then be created on the Library sheet using the 2D drafting elements.
Setting the TMRF (Template Reference) attribute of a SYMB (Symbol Instance) element or SLAB (Special Label) will cause the referenced SYTM to appear on the relevant Sheet. The Symbol can then be positioned, sized and orientated to suit. Refer to
Scaling and Mirroring Special Labels
for further information about description of scaling and mirroring SLAB elements.
Figure 17:2.
DRAW Database Hierarchy - Symbol Template and Related Elements
