DRAW Reference Manual
Annotating Structural Elements in DRAW
: Angle from a P-line
Angle from a P-line
The p-line direction as defined above may be used to set an angle. This is true of any element with an ADEG attribute, such as a drafting primitive.
However, for Labels (GLAB, SLAB) and View Notes (VNOT), there is an additional possibility. If the p-line is used for position, then the same p-line may also be used instead of the ADEG attribute to store angle.
The syntax for p-line angle is as follows. This is normally used to set the ADEG attribute:
ANGle PPLINe
word
OF
element_identifier
plxyz
ANGle PPLINe
word
OF
element_identifier
plxyz
ADEGrees PPLINe
word
OF
element_identifier
plxyz
If p-line is required for angle on a Label or View Note, there is a simple way of setting it. This is done using the following syntax:
ANGle PKEY
or
ADEGrees PKEY
This command first checks that a p-line is in use for position, and uses it to define the angle of the Label or View Note.
The
ANGle PPLINe
syntax may also be used to store p-line for angle in the database. However this will only be done if
both
of the following criteria are satisfied:
The p-line identified must be that used for p-line position
The p-line direction syntax must not be qualified by a p-line axis
