DRAW Reference Manual
Miscellaneous Text Facilities
Within DRAW, text is used by Dimensions (dimension line and projection line text), Labels, and as part of the 2D-drafting facilities (TEXP elements). The text is set using the BTEX, DMTX or PLTX attribute of those elements, as appropriate. (Refer to
Special Labels and Text Label Templates
for further information about BTEX, also the ATEX, DMTX, PLTX and ETEX text attributes.)
The system now supports both AVEVA fonts, which are supplied with the product, and standard Windows True Type fonts.
