#Tname is the Template codeword, which enables complex text strings to be defined once in a Text Template (TXTM element). This template may then be referenced from other elements.
name refers to a text template TXTM. For example:
The codeword #T/name must be the only content of the text string. The referenced text string may contain intelligent text codeword strings. However the BTEX attribute of a TXTM cannot itself contain a #T codeword since this could lead to recursion.
