With local positioning, Labels will be positioned around their significant design elements in such a way as to minimise Label overlap and leader-line crossing. Labels will not be moved from their initial positions unless it is necessary. If they are moved then, as far as possible, leader lines will be straight and at ± 45° to the VIEW axis.
With remote positioning, labels will be positioned around the VIEW border. It is possible to define a margin outside the VIEW frame that will define the positioning of the Labels. It is also possible to define a side of the VIEW frame alongside of which repositioned Labels will
not be placed, and the minimum permissible gap between any two Labels can also be specified.
