DRAW Reference Manual
Labelling : Autotagging : Label Generation
UPDATE element_identifier TAGG
If element_identifier refers to a TAGR owned by a LAYE, then all Labels defined by the given Tag Rule will be generated.
If element_identifier refers to a LAYE, then all Labels defined by all of the member Tag Rules of the Layer, plus those owned by the TRST referenced by the Layer’s TRSF attribute will be generated.
If element_identifier refers to a VIEW, SHEE or DRWG then this is equivalent to giving an UPDATE TAGG command for each Layer beneath them in the hierarchy.
If element_identifier is omitted then the current element is assumed and one of the three previous conditions will apply. Tag Rules will also be updated by UPDATE ALL.
When a Tag Rule is updated for the first time a set of Labels will be created and drawn which can then be edited if required. Refer to Label Editing and Copying for further information. Each Label will have its SORF (source reference) attribute set to refer back to the TAGR.
In the latter two cases, whether or not an element is excluded depends upon the position of the p-point to which the Label is to be attached. Note that Labels will be created for elements that are not drawn because they are obscured by others. If these Labels are not required it is recommended that they are made invisible by setting LVIS FALSE. Deleting them will only cause replacements to be generated on the next UPDATE TAGG command.
When a Tag Rule is updated a second (or subsequent) time, existing Labels will not be deleted and recreated from scratch unless the OVERWRITE option is used, i.e.
