Data Model
Manu Database
Manu Database Elements
: Plate Part Element (MPLATE)
Hull Manufacturing Element
Primary Element
Attributes:
Name
Name of the element
Description
Description of the element
AnyCha
True if chamfer is defined on any edge
AsPart
True if assembly part.
AsPlno
Number of assembly plate parts
AsPrno
Number of profiles on assembly part
AsPwle
Total length of weld in assembly part
Bent
Bent flag
BlsLen
Length of blasting contours
BrnLen
Length of burning contours
ManCog
Center of gravity
Corrug
True if corrugation is defined on the plate part
CrcAng
Turning angle for least circumscribed rectangle
CrcLw
Length and width of circumscribed rectangle
Curved
True if curved plate part.
DatInt
Date
DatTxt
Date
Dest
Destination
FncCd
Functional description code
FncTxt
Folded
True if folded
HolGrd
True if any hole in the plate should be ground
Knuckl
True if knuckled
ManTyp
Manufactured type for example. Plane, Curved,...
MrkLen
Total marking length
PanSid
Side of panel
PlArea
Area
PlaTyp
Type of plate for example. Plate, Bracket, Clip,...
PosNo
Position number
ProSid
Plate side with most profile markings
PrtIdl
Long part id
PrtIds
Short part id
PrtLst
Parts list name
QuaCd
Quality code
QuaTxt
Quality
SdtTxt
Splitting date
Streat
Surface treatment
Thickn
Thickness
TypeCd
Type code
TypeCe
Type code
ManWgh
Weight
Legal Owners:
Built Profile Part Element (MBPRO)
Production Parts Panel Element (MPANEL)
Manufacturing Package Folder Element (MPKGFL)
Legal Members:
None
