Data Model
Draft Database
Draft Database Elements
: Hull Symbolic View Element (HSVDEF)
Draft View Element
Attributes:
Name
Name of the element
SVType
Hull symbolic view type
SVComNo
Hull symbolic view component number
SVComType
Hull symbolic view component type
SVLooking
Hull symbolic view looking direction
SVPltype
Hull symbolic view plane type
SVCurtype
Hull symbolic view curve type
SVScale
Hull symbolic view scale
SVPOnly
Hull symbolic view pan only
SVReflect
Hull symbolic view reflect Y/N
SVSHProfile
Hull symbolic view profile Y/N
SVShSeam
Hull symbolic view shell seam Y/N
SVShThick
Hull symbolic view shell thickness Y/N
SVAuto
Hull symbolic view auto Y/N
SVAsPlane
Hull symbolic view as plane Y/N
SVDraInters
Hull symbolic view draw inters Y/N
SVDraPlaneV
Hull symbolic view draw plane V
SVRSO
Hull symbolic view RSO Y/N
SVCAxis
Hull symbolic view coord axis Y/N
SVCrosSSym
Hull symbolic view cross sect symbol Y/N
SVDrPipe
Hull symbolic view draw pipe Y/N
SVDrEquip
Hull symbolic view draw equip Y/N
SVDrCWay
Hull symbolic view draw cableway Y/N
SVDrStruct
Hull symbolic view draw structure Y/N
SVDrPVol
Hull symbolic view draw pvol Y/N
SVDrVent
Hull symbolic view draw ventilation Y/N
SVDrAccom
Hull symbolic view draw accommodation Y/N
SVName
Hull symbolic view name
SVPName
Hull symbolic view pan name
SVPlXOrigin
Hull symbolic view x1
SVPlXUAxis
Hull symbolic view x2
SVPlXVAxis
Hull symbolic view x3
SVPlYOrigin
Hull symbolic view y1
SVPlYUAxis
Hull symbolic view y2
SVPlYVAxis
Hull symbolic view y3
SVPlZOrigin
Hull symbolic view z1
SVPlZUAxis
Hull symbolic view z2
SVPlZVAxis
Hull symbolic view z3
SVLXMin
Hull symbolic view xmin
SVLXMax
Hull symbolic view xmax
SVLYMin
Hull symbolic view ymin
SVLYMax
Hull symbolic view ymax
SVLZMin
Hull symbolic view zmin
SVLZMax
Hull symbolic view zmax
SVDBefore
Hull symbolic view depth before
SVDBehind
Hull symbolic view depth behind
SVPosCoAxis
Hull symbolic view coord axis pos
SVPlExclude
Hull symbolic view exclude panels Y/N
SVPanels
Hull symbolic view panel elements
SVBlExclude
Hull symbolic view exclude blocks Y/N
SVBlocks
Hull symbolic view block elements
SVCurves
Hull symbolic view curve elements
SVAssemblies
Hull symbolic view assembly elements
Legal Owners:
View Element (VIEW)
Legal Members:
None
