Data Model
Dictionary Database
Dictionary Database Elements
: User Defined Attribute Element (UDA)
Attributes:
Name
Name of the element
Description
Description of the element
Ukey
UDA key - internal unique system identifier
Ablength
Minimum abbreviation length for a UDA/UDET user defined name
Utype
Type of the value. INT, REAL, TEXT, REF, LOG, WORD, POS, DIR or ORI
Ulength
Length of data or text
Uunits
Units of attribute values (bore/distance/text)
Oldkey
Old key
Udacpy
UDA copy
Rptxt
Text used when presenting the attribute to the user
Elelist
Types of elements (including UDETs) to which this attribute applies
Reflist
Types of elements (including UDETs) that can be pointed to by a reference attribute
Dflt
Default value for the attribute
Ucat
Category on forms
Upseud
Set true to calculate attribute value rather than store it in a database. User code must be provided
Uprote
Set true to disallow viewing the attribute in a protected database
Uhide
Set true to hide attribute on forms
Uteams
Teams that will see a hidden attribute
Uhyper
Set true to treat attribute value as a named link to an external resource
Uconn
True if the UDA value should appear on the reference list form
Udpend
list of attributes that this attribute depends on
Udtabl
Determines if UDA is to be indexed in a table for fast access
ULVOpt
Determines if UDA valid values or range limit is optional
Udname
User defined name
Legal Owners:
User Defined Attribute Group Element (UGROUP)
User Defined Attribute World Element (UWRLD)
Legal Members:
User Defined Limit Element (ULIMIT)
User Defined Valid Value Element (UVALID)
