Data Model
Elements in Template Category
: Rule Repeat Element (TMRRELEMENT)
Template Element
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
Tmrrule
Template Repeat Rule
Tmrmaster
Template Repeat Master Duplicate Element
Tmrowner
Template Repeat Owning Element
Orrf
OffType
Offset type: DELTA, LINEAR, RADIAL
DeltaEast
Easterly Offset applied to repeat elements
DeltaNorth
Northerly Offset applied to repeat elements
DeltaUp
Vertical Offset applied to repeat elements
Offdistance
Offset distance applied to repeat elements
Offdirection
Offset direction applied to repeat
DelAngle
Angle applied to repeat elements
AxiPosition
Axis position applied to repeat
Axidirection
Axis direction applied to repeat
Rorient
True if repeat item is re-orientated upon rotation
MaxRepeat
Maximum number of Repeat items created
Legal Owners:
Repeat Set Element (TMRPSET)
Legal Members:
None
